- 21 Apr 2007
So i've been made an offer for an entry level dev role, i've been learning to code myself for about a year and a bit, following that I did a bootcamp full time.
I wanted to ask some advice on what I should do, whether to take the role or not, perhaps i'm being silly and worrying about nothing. The tech stack is pretty much bootstrap on frontend (which is easy no problem) but the backend I believe is PHP. So i'd have to be learning an entirely new language/framework for the role as it has me concerned i'll be able to perform.
Is this a normal thing in tech? They really liked my portfolio of work and spoke highly of it at interview and that's possibly why they just think they can take me on and i'll learn.
My specialities lie mostly in frontend with React (But of course most libraries/frameworks are similar), I can easily build a pretty/fancy UI no problem if i'm handed a design spec, and i've dabbled in backend work/database stuff. The role they are taking me on for is basically full stack but with tools I just don't know and it has me concerned. The other thing that has me somewhat concerned is they are a smaller company with a not very large dev team, and that leads me to worry about lack of mentorship / oversight (The role is also fully remote which is a dream sure, but as a first role I believe can present additional challenges).
The issue I face right now is entry roles are few and far between and there's probably a lot of competition. I'd love to be hired on doing a role which basically matches my current skills, as I could hit the ground running no problem and begin contributing easily.
What would you do in my situation those of you who are wiser and more experienced? The smart choice is to just take the role, get experience on my CV and stop being a worrier I guess.
And other note is, i've only been applying properly for around 3-4 weeks, but rejections have of course come in during that time shaking my confidence of finding something that's a better fit.
