Entry level Water cooling spec - Need you to check this over...
27 Oct 2006
London
I've been a lazy for years and have so been meaning to do water so here goes.
I'm going with 3/8" 1/2" tubing ... Would have preferred smaller but am guessing that will compromise performance ?
I think I'm quite happy with the kit except the radiator (1st choice was the RX240 but it's out of stock)...
What do you guys think ?
(Yes I'll add a few fans to the cart too)
Here's my cart ...
D-Tek Fuzion V2 Universal CPU Block (AMD Socket A/754/939/AM2, Intel 478/LGA775/423/771/603/604) £45.99
(£39.99) £45.99
(£39.99)
XSPC Dual 750 Bay Reservoir & Pump - Clear XSPC Dual 750 Bay Reservoir & Pump - Clear £40.24
(£34.99) £40.24
(£34.99)
XSPC RS240 120mm Radiator - Black XSPC RS240 120mm Radiator - Black £22.99
(£19.99) £22.99
(£19.99)
Feser One UV Reactive Coolant 1 Litre (Purple) Feser One UV Reactive Coolant 1 Litre (Purple) £8.04
(£6.99) £8.04
(£6.99)
TFC Compression Fitting G1/4" Thread 3/8" ID/1/2" OD - High Flow TFC Compression Fitting G1/4" Thread 3/8" ID/1/2" OD - High Flow £3.78
(£3.29) £22.68
(£19.74)
XSPC 3/8" High Flexibility PVC Tubing - 1m XSPC 3/8" High Flexibility PVC Tubing - 1m £2.86
(£2.49) £5.72
(£4.98)
Sub Total : £126.68
Shipping cost based on delivery to home, with:
FREE SHIPPING (DPD Next Day)
(This can be changed during checkout) Shipping : FREE
VAT is being charged at 15.00% VAT : £19.00
Total : £145.68
Go to Checkout
