Environmental monitoring
Permabanned
26 Oct 2004
Isle of Wight
This is something I want to look in to for our little server room. It has gotten to the point where it gets really hot without the aid of air-con (temp unit in there currently, fixed unit is half way through being installed).
So temperature monitoring is essential, flood detection would also be hugely useful as we are at risk.
Whatever the solution, it would be nice if there were some generic digital/analogue inputs as well - one of the downsides to the aircon unit is that it relies on a pump to remove water from it's drain (as there is no drainage available vertically) - it would be cool to be able to monitor this somehow, although I haven't quite worked out the best way yet (the most reliable solution I think would be a junction in the pipe somewhere with a float and a microswitch to detect water build up), although I'm certain there is a reasonably simple solution.
I had the idea of using an Arduino combined with an ethernet module and SNMP stack (there is one available for the Arduino) so that it can be monitored with our existing monitoring tools. This is certainly the most interesting and coolest solution, although whether I should trust something of such importance to a home-brew project, I am unsure.
Is there something reasonably cheap out there that can match this brief?
Have you got a BMS system in your building, if so it might be the best solution? The pump may well have a set of volt free contacts for providing an alarm, if not there are other ways such as monitoring the current to the pump.
You could also connect a temperature sensor and leak detection system to the BMS and most systems with a head end have the ability to be set up to send alarm emails and many can send SMS as well.
At my last place we installed one of these after our air con broke down (it was like a sauner). Cheap bit of kit with some extra modules you can install. Did the job nicely.
http://www.theclimate.co.uk/
That is a fantastic suggestion. One on it's way with a water sensor as well.
I just need to figure out how to utilise one of the analogue inputs for monitoring the aircon pump now :)
