- 9 Jun 2009
Basically, i had finally figured out a way to cable tidy the Stacker 831,was really happy put it back together, plugged everything in, turned it on, nothing for 10 secs then BOOM it poped and a flash of light came from the bottom of the motherboard. Im guessing its fried the motherboard, I do have a fairly decent OCZ stealth PSU, so im hoping nothing has gone with it, is there a chance it has? Im going to my grandads tomorrow to test the graphics card, because thats the most expensive part in my PC. If anyone has done something similar, was your system fine apart from the motherboard, and what most likely caused it? im guessing the case got contact with the mobo somehow, does this sound correct?
Thanks in advanced
Thanks in advanced
