- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
After obtaining the new Epic Gear mouse and gaming surfaces on Friday I decided it would be rude not to do a product review, as this is a relatively unknown product.
After grabbing a retail boxed Meduza Hybrid mouse. I have used this mouse extensively this weekend. I have tested the mouse on the following games.
So as you can see I did extensively test this out! Anyway onto the actual review.
The Box:
The packaging is great. It allows you to view the mouse behind a clear plastic insert which is shaped to the mouse, thus allowing you to feel the shape of the product prior to purchase (doesn't really make much difference to etail though lol) The packaging is sturdy (great for delivery) and the print on the box has a very extensive list of features and benefits. The design of the box is great, it is black with a reflective cat/panther type front fascia on the box, making the product look appealing.
Inside the box there is:
Instructions
Mouse
Driver Disk
Initial Setup:
Unboxing the mouse took just a few moments. The mouse is of course, USB, like every mouse available now. I plugged in the mouse and Windows detected the mouse straight away, the mouse lit up as it should, and Windows quickly installed the neccessary generic mouse drivers. The mouse worked straight away. Next up was the driver/software installation. The CD was installed and I noted that software is a whopping 6megabytes. The software installed very quickly. The software allows you to customise a big range of options and save profiles to your mouse.
Tracking Quality:
The quality of the mouse is very good, the feet are extremely smooth and the mouse doesn't suffer any judder in the usage I had from it. I used this on both the EpicGear gaming surface and my own QcK mouse pad from Steelseries and the tracking was spot on with both. The mouse has 3 tracking modes, Optical, Laser and Hybrid (combination of both), the native optical mode, and the native laser modes both track just how a high end laser of each type should. The laser mode is mega high precision whilst the optical offers the quality and feel of a great gaming sensor also. Myself I prefer optical mice as laser mice seen a little too "perfect" in the tracking itself. The Hybrid mode for me was by far the best with the smooth feeling of the optical sensor, but the precision of the laser sensor.
I ended up trying the mouse for an extended period in all 3 modes, personally I felt the HDST mode was by far the best.
Switching from mode to mode is simple, you just flip the mouse over and on the bottom is a small switch to allow you to swap the mode whilst the mouse is plugged in and on.
Sturdiness:
The build quality of the mouse feels great, the mouse feels just right, but one of the key issues is that some people will prefer heavy mice, and others prefer lighter mice. Epic Gear could have offered a weighting system to make the mouse more customisable.
Gaming:
Gaming for an extended period of time, was a delight, I enjoyed playing games for much of Saturday (and I told my wife it was to review a product for work, so she didn't complain - not that she does very often anyway) I will admit that whilst I'm not the best BF3 player in the world, my accuracy did seem to improve whilst using this mouse on Saturday. The software allows you to customise the DPI and acceleration to perfection too, which is good, you can change and edit the default profiles too, which are stored on the mouse, so if you don't like a bloated OS you can remove the software once you have confirmed the profiles and saved them to the mouse. This also allows you to plug your mouse into various PC's and have your settings ready to go.
Extended Use and Comfort:
The mouse is very ergonomic and comfy, the only downfall is that parts of the mouse is not rubberised, it is a shame as the rubberised finish gives a much nicer feel, and on the mouse where your thumbs rests you can feel the hardened plastic a bit. The mouse cable is excellent in quality with a great looking red/black braided cable which protects the internal wiring, and makes this product very hard wearing and long lasting.
In Summary:
Normally unknown branded gaming mice do seem to be a little rubbish in general, but using this mouse I was pleasantly surprised. Don't get me wrong, their are a couple of things which could have been done to finish off the product, but in general this is a very good product which does sit near the top of the tree in the gaming mouse area. If I have purchased this mouse I would have not been dissapointed at all. Especially if I was undecided between buying optical or laser.
I would rate this product 8.5/10, it lost points for the lack of weight adjustment and the mouse could have been 100% rubberised.
Pros
- Worlds first true dual sensor tracking system with 3 modes.
- Offers optical and laser benefits, and a combination of both.
- Software is easy to use and has a great UI.
- Accuracy is spot on.
- Ergonomic.
- Claims of jitter free tracking - which was evident.
- Nice lighting system with on the fly profile/DPI changing.
- Excellent braided cable.
Cons
- Lack of weight system
- Plastic parts of the mouse seems a little cheap looking
We have stock, we are exclusive! Buy from us now!
EpicGear Meduza HDST Dual Sensor 6030 DPI Gaming Mouse @ £54.98 inc VAT
Meduza is equipped with not one, but two sensors, one being laser and the other being optical. EpicGear has managed to combine the advantages of the two types of sensor onto one platform, thus providing users with lightening fast laser speed, up to 6030 DPI, and extremely stable optical precision (jitter free). Meduza is ideal for all types of games and any sensor preference. Simply choose the desired type of sensing mode on the back of the mouse between - Laser, Optical or HDST.
Co-developed by pro-gamers, every line, every curve and every concave on the Meduza is thoroughly studied and analyzd for the one purpose of extreme support and comfort for even the most hardcore gamers after long hours of play time.
- Three switchable sensor modes: Laser, Optical and HDST (Laser + Optical)
- Advanced Algorithum Logic Technology to restrain common problems like Jitter, Skip and Drift
- Optical mode: Up to 3200 DPI (four modes)
- HDST Mode: up to 4800 DPI (four modes)
- Laser Mode: up to 6030 DPI (four modes)
- 1mm Lift off Distance
- Tracking Speed of up to 200 IPS
- Acceleration Speed of up to 30G
- Longevirt Gaming Keys of 10 million clicks
- On-the-fly DPI change
- 7 buttons, 6 fully programmable
- 5 Gaming profiles with customisable LED Colour
- 15 Sets of Customisable Long Macros
- ARM 32 bit Cortex M3 CPU
- Onboard Memory of 128KB
- Independent X/Y Axle Change via GUI Laser Mode
- Supports Driverless Plug and Plug
- Angle snapping support with Laser Mode
- Auto Power Saving on/off via GUI
- Ultra swift Big Teflon Feet
- X-Braided Cable for Durability
- Ferrite Bead Cable for Durability
- USB2.0 Full Speed: 1000Hz Report Rate
- 2-Meter Cable
- 2 Year Warranty
Only £54.98 inc VAT.
ORDER NOW
- Battlefield 3
- Sniper Elite V2
- Skyrim
- Borderlands
The Box:
Instructions
Mouse
Driver Disk
Initial Setup:
Tracking Quality:
Sturdiness:
Gaming:
In Summary:
Pros
- Ergonomic.
Cons
- 2-Meter Cable
- 2 Year Warranty
ORDER NOW
