episodes from liberty city problem
23 Aug 2006
North Wales
Hi i brought episodes from liberty city not long ago but have only just got round to playing it but i cannot change the resolution past 800x600 it is saying that iam using all my video ram.
My spec is ati 6990, 6gb ddr3 ram, i7 processor @4gig
so i should be able to run it no problem.
Right click on the shortcut on the desktop, then go to properties, and change the "Target" so those two commands are on the end, after the quotes.
I had exactly the same problem with my 6990. I solved it by creating a text file in notepad called "commandline" (no quotes). In the file put "-availablevidmem 0.5" (no quotes again. Save where the EXE is and Bob's ya uncles brothers dog as they say:)
