Equation Rearranging Help
Permabanned
21 Apr 2004
Southampton University
Trying to follow through a bit of working and i've got a bit stumped where the jumps have been quite big...
Would someone mind explaining how the rearranging gets the following equations?
I think I just about get the first step, the second to third is where i'm where really confused!
Cheers :)
Ok to get from 2 to 3,
multiply 0.849, PI/4 and 1/(4^0.63) together to give 0.278 (3dp)
So we now have Q/CD^2.63=0.278*(hf/L)^0.54
Then take the 0.54th root of eveything, ie increas everything to the power of 1/0.54 which is 1.85.
This gives (Q/CD^2.63)^1.85 = 0.0939*(hf/L)
Then multiply by L and divide by 0.0939 to get the answer hf=10.21*L*(Q/CD^2.63)^1.85
The last step must be subbing in values for L, C and D.
ALso allow for rounding errors in the values above, they may not be exact as given in your OP
no worries, random values though, whats it for?
It's the Hazen Williams Formula, for hydraulics, using it to calculate head loss due to friction so I can then calculate flow... There's a pump thrown in there too, just to complicate it a bit :p
