Equipment for adsl connection?
2 Oct 2006
i've had a bt line installed, adsl24 are activating the line on thursday, what equipment do i need specifically?
BT line > ethernet converter > into netgear 834G > ethernet to pc?
BT line > into netgear 834G > ethernet to pc
Just remember to put microfilters into the appropriate phone sockets
do i get the microfilter and correct wires with the router?
Normally yes (well, that's certainly the case with new Netgear routers). Normally you get:
- One microfilter.
- A lead that goes from the data socket on the microfilter into the back of the router, providing the connection to the phone line.
- An ethernet cable that goes from an ethernet port on the router into the ethernet port on your PC.
