Wyvern971 said:At present I have a load of 2600 routers and an 1841,
I have 1 ADSL WIC, and 1 4 port ethernet switch WIC
For a lab should I still be considering serial interfaces?
or should I just go for ethernet?
Thanks for looking
Wyv
Wyvern971 said:Most of it will be used for certification (hopefully) so I guess I should stock up on a few serial interfaces then.
Will a NM-8A/S work in a 2612?
Wyvern971 said:At the moment CCNA, but want to eventually move up to CCNP -> CCSP and possibly further so I want a reasonable set of equipment which is fairly expandable
V-Spec said:You should be fine with 2600s 1841s etc
ebay is your friend to find bits and pieces for labs, you can get wic-1t's for about £20, extra memory etc for not much more. Especially as 2600s are now end of life and quite old, however they still support new IOS along with most protocols..
Wyvern971 said:I know, I've maxed out the mem/flash on the 2600s to 64/16
The 1841 is runing with 256/128
All I'm after now are the interfaces
Incidentally the 2612s have a token ring port (I have to admit I've never used token ring, though I do understand the priciples)
Is it worth doing anything with the token ring interfaces (and what do I need to connect them as the only token ring systems I remember seeing were BNC and these are RJ45) if a 10Mb hub is sufficient I have a 24port one kicking about somewhere.
V-Spec said:You won't need to know/do/think anything about token ring. It is a long gone technology, i've been working in networking for 6 years and the closest i've ever come to token ring is a pile of knackered kit in the corner of a building being knocked down![]()
Wyvern971 said:T'was what I thought but wanted to check anyway
EDIT:My manners seem to have gone for a walkabout, thanks for your help m8![]()
