Erm....help (VLC)
26 Jan 2007
Having lost my XP disc, I had no option but to try ubuntu.
Finally got it installed etc, but am struggling to install VLC player. I Just can't seem to install it, (I tried from the apps menu, but it gave an error message). I also tried from ubuntu.com and downloaded this .deb file which then gave me an error (cannot install vlcnox or something)
Any help?
You don't have the deps maybe.
Not sure why the apps menu (which is packagekit) didn't work, but thy this:
Programs >> Accesories >> Terminal
Code:
sudo -s
# type ur password
apt-get update
apt-get install vlc
# may need to say yes a few times
exit
exit
what is the error message? seems important to get your package manager working. Also have you tried the synaptic package manager? (in the menu somewhere)
