Erm...HELP!
28 Mar 2006
Jarrow, Tyne And Wear
just finished disassembling, cleaning, renewing thermal compound, etc. and i just reassembled it all, only to find that when i try switch it on all the fans spin up, etc. but no signal to monitor, GFX is properly seated, connect, etc. the power cable is in...any ideas?
have successfully identified the problem as two of my RAM modules, the system won't boot with either of them in, but boots fine with the other two! OCZ lifetime warranty covers defective modules right?
noticed a tiny difference on the side as well, the modules that are working have latency written on the side, it says 3 - 4 - 3 - 15 or something along those lines, and the ones that don't work say 4 - 3 - 3, would that matter if they were being used alone, seperate from the working two?
