Ok. I purchased a Corsair H50 from the MM.
Got it installed and booted the PC. Went into bios to check out CPU temp. Ok it's all cool (pun intended).
Boot into windows and open CPU-Z. CPU temp=0. :S
Open HWMonitor CPU temp=0.
Run prime95 for 1 minute. CPU-Z and HWMonitor CPU temp=9.
Now that cannot be correct. I'm using a h50 not liquid nitrogen.
Advise?
Advise?
then I thought to myself... It's only water... then i was like
Whats wrong?!
