Do you have a link got me so I could follow a guide or something ?Sounds like it is a job for a Windows recovery drive... I've only ever seen that when an essential driver or core windows file had gotten corrupted
Very good question, I'd recommend you back up anything valuable just in case. It could just be a random bit flip as a one off.Very ODD ! Restarted it and it’s now took me to my user log on so what could the problem be?
Have you disconnected or reconnected anything?
Link wise: https://support.microsoft.com/en-gb...-windows-99a58364-8c02-206f-aa6f-40c3b507420d
Repair procedure is fairly self explanatory but theres inevitably a guide for it too. For now I'd focus on getting that reassurance if a backup sorted amd hope it doesn't come back.
Thanks mateI guess all you can do is wait and see whilst the wheel spins
You can look in event viewer when it finishes for hints of why it crashed and what it's been up to.
I can’t get on the PC it’s just dead slow all of a sudden nothing loads after I enter password to log onOpen the command prompt and run the command line sfc /scannow to see if anything in windows has been corrupted.
