Error 55 , memory not installed strange voltage?
12 Jun 2007
Ireland
Everything was fine till couple days booted up and said on the board code 55 ( memory not installed) , reseated the memory still the same. So increased VCCIO voltage to 1.2 seamed to do a job , but crashed few times after that.
also noticed that my memory is set at 1.5 v , but the motherboard ups it to 1.65v or more for some reason.
any advice ?
thank you
Could be a faulty stick/motherboard?
Try taking out all the RAM and test 1 stick in all the DIMM slots to rule out faulty motherboard, then try each stick on it's own and run memtest.
strange put my bios at default then the mob was putting dram voltage to 1.8v for some reason to make it 1.5v i had to put 1.2550v :confused: .
will reaseat heatsink see how it will go then.
edit: somehow issue sold it self out no idea how , in asus forums they said to flash bios to 1408 and clear cmos after hopefully will not happen again
These errors to me sound like a bad stick of memory or corrupt bios. I would still look to memtest this system just to check the sticks are working fine.
55 error means the IMC of the CPU is capable of the frequemcy but your RAM need tuning.
