I'm considering a new (old) car, namely a Jag S-type 4.2L n/a
So torn between spending (much) more and getting a better one or spending less and getting one needing a bit of work. The cheapskate in me says the latter; realistically the difference in cost is a couple of grand.
Now the car I'm looking at has a few cosmetic issues none of which are particularly major (bits of missing trim, that sort of thing) but also has a check engine light and a check of the fault codes have revealed an issue with the bank 1 sensor 1 O2 sensor. The car also has an irregular idle. It seems to drive fine without any obvious gearbox issues.
So I suppose my question is, how much is it likely to set me back to sort out the pre-cat O2 sensor? My local garage muttered something about £2-300 and advised me to steer clear
