Ok im tryin to install XP Pro on a brand new 160GB Western Digital SATA, currently windows is on 1 of my storage drives.
When i first plugged it in, windows said it had to change it to a 'dynamic' disk, had never seen that before, but wouldnt let me format it before i did that. Anyway after then, i formatted it in Windows.
Thought i could just reboot with that HD plugged in and install windows on it, but wouldnt let me without formatting, so i did, NTFS (as you do)
ANYWAY
formats fine, copies all the setup files fine, restarts....gets to the 'press any key to boot from cd', i just leave it...and it should load up the HD and carry on with the Windows install...but i just get the error 'Error loading Operating System'
yes i did google it, checked here but that doesnt help, have latest BIOS for my asus a8n-sli, checked here also, says to 'Go to the BIOS settings of your machine and change the translation method used to access the hard drive from the default setting “Auto” to “Large” which i also tried...the error doesnt come up, but it just freezes.
Now is this brand new HD ******, or is it some silly problem i dont know about and can fix?
thanks
ANYWAY
thanks
