I was wondering whether anyone in the know would be able to help narrow down a problem I'm having my 40D/17-55mm.
Sometimes when shooting, the shutter will open (from what I can hear), only the image won't be taken and the only thing I get on the screen will be the following message:
I'm pretty confident it's not the body because I have a Sigma 10-20mm that doesn't have any issues at all. The only area where there's any confusion is that the problem only seems to come about when focusing beyond 20mm-ish (so hard to be 100% that it's not the body).
Has anyone had a similar problem or know anything about it that could set me on the right path to get it sorted?
Cheers
Err 01
Communications between the camera and the lens is faulty. Clean the lens contacts.
Cheers
