Error with LogiLDA.dll
29 Jul 2010
Lincs
I've got the logitech G Hub software installed, which has been fine. But just recently on booting up I now get a runDLL error of
There was a problem starting C:\3Windows\System32\LogiLDA.dll The specified module could not be found
I'm not sure if this happened after a windows or logitech update, but I've uninstalled and re-installed the G Hub software a couple of times and it hasn't cured it. The only option I seem to find online is to just disable the LDA (Logitech Download Assistant) but I'd rather fix the cause than the symptom if possible.
Any ideas?
