My Christmas present came early and my Mother just said I could install them if I wanted to 3 x Akasa 140mm, 3 x SGT 1850 120mm.
So anyway, they were a ***** to fit on without taking my machine apart, just couldn't get the Apaches in at the top of the case, so I took my computer apart, fitted them and built it back up... BANG. CPU_LED. Awwww maaaannn !
Take my cooler off, thinking I've knocked it or something (which is also a ***** to fit imo!) and inspect the CPU. Nothing, fine... Inspect the socket, fine.. What the hell?!
By this point I'm raging, and I'm freaking out thinking I've screwed something up. Re-seat the heatsink, still nothing. Take it off again, a good hour or so later looking for loose connections or something I notice I hadn't plugged my 12v into the MB cause I was raging and freaking out haha...
Anyone else ever just missed something so stupid then realised?
p.s. Awesome fans. Oh so quiet when they're turned down, but give some awesome cooling on full whack. Not too loud either
