errors in GFX card.
25 Jun 2005
Hi all,
My gfx card is producing lines on POST and then when it gets up to Windows GPUz still shows it to be a 8800GT but is running a 16 bit mode.
I don't have access to a second card to try it out, if I produce a video can anyone have a look at it to see what they think.
If we do think its the card can anyone suggest a replacement for a 8800GT 512Mb its going to be on a 1600 x 1050 screen with the rest of the spec in my sig.
same thing happened to my 8800gt yesterday. I know what you'll think when i say this, but to fix it i took the plastic fan socket off + the cooler, then popped it in the oven at 200 degrees for 8-9 minutes. Works great now!
