Errors on Overclock
15 Jan 2006
UK South Coast
Hello all, when I run LinX 0.62 it stopped after 13 runs with error ?
As you can see the GFlops below look great so I was wondering what could have caused the stop ????
thanks for any idea`s
Cheers
mrix
CPU frequency: 4.000 GHz
Number of CPUs: 8
Number of threads: 8
Parameters are set to:
Number of tests : 1
Number of equations to solve (problem size) : 11530
Leading dimension of array : 11544
Number of trials to run : 20
Data alignment value (in Kbytes) : 4
Maximum memory requested that can be used = 1065053536, at the size = 11530
============= Timing linear equation system solver =================
Size LDA Align. Time(s) GFlops Residual Residual(norm)
11530 11544 4 20.258 50.4558 1.295321e-010 3.445333e-002
11530 11544 4 20.257 50.4576 1.295321e-010 3.445333e-002
11530 11544 4 20.303 50.3439 1.295321e-010 3.445333e-002
11530 11544 4 20.275 50.4126 1.295321e-010 3.445333e-002
11530 11544 4 20.283 50.3931 1.295321e-010 3.445333e-002
11530 11544 4 20.272 50.4218 1.295321e-010 3.445333e-002
11530 11544 4 20.262 50.4471 1.295321e-010 3.445333e-002
11530 11544 4 20.275 50.4128 1.295321e-010 3.445333e-002
11530 11544 4 20.271 50.4228 1.295321e-010 3.445333e-002
11530 11544 4 20.269 50.4280 1.295321e-010 3.445333e-002
11530 11544 4 20.278 50.4074 1.295321e-010 3.445333e-002
11530 11544 4 20.300 50.3506 1.295321e-010 3.445333e-002
11530 11544 4 20.268 50.4312 1.848241e+003 4.916005e+011
re:
Hi there, my spec below
EX58-UD5
cpu is a i7 920
XMS 6GB
Max temps while testing were 80c but on average were around 75c
My main voltage settings are..
CPU Vcore is 1.36250v
QPI / VTT Voltage is 1.395v
I just thought if the times and Gflops were all the same all should be fine?
Thanks for the help
mrix
