Eset Smart Security - Filtering Modes?
6 May 2008
Hi all, I am kind of new with "Eset Smart Security" just wondering what do you have your filtering mode set to?
Automatic mode - This is the default mode and is suitable if you do not need to define rules. The automatic mode allows all outbound traffic for the given system and blocks all new connections initiated from the network side.
Automatic mode with exceptions (user-defined rules) - Enables you to add custom rules.
Interactive mode - Allows custom configurations. When a communication is detected without a corresponding rule, a dialog window displays with the option to allow or deny the communication. You also has the option to create a new rule to always allow or deny all similar communications in the future.
Policy-based mode - Blocks all connections that are not defined by a specific rule to allows them. This mode allows advanced users to define rules that permit only desired and secure connections.
Learning mode - Automatically creates and saves rules and is suitable for initial configuration of the Personal firewall. No user interaction is required, because ESET Smart Security saves rules according to predefined parameters. The Learning mode is not secure, and should only used until all rules for required communications have been created.
Interactive, I prefer to control every program that has access and automatic used to be useless in v3. v4 adds automatic with exceptions which I've yet to try but I'd still prefer to control everything.
