ESO addons, where do they go? (Elder Scrolls Online)
19 Oct 2002
The guy that answered me at the site I got it from is being a jerk so, the instuctions on the site says put it in a folder called live, but I have none,
Copied from here https://www.esoui.com/forums/faq.php?faq=install
1. Download your chosen addon
2. Extract the files to a folder on your desktop.
3. Open your ESO folder.
If using a PC, the typical default install path is: C:\Users\< username >\Documents\Elder Scrolls Online\live\
Or you can use the windows variable by pasting it into windows explorer: %userprofile%\documents
4. In the 'live' folder, create a new folder called AddOns (if it doesn’t already exist)
5. Open the AddOns folder
6. Copy the files from the folder on your desktop into the AddOns folder
7. Your final path should look like:
C:\Users\< username >\Documents\Elder Scrolls Online\live\AddOns\< AddOn A FolderName >\< files >
C:\Users\< username >\Documents\Elder Scrolls Online\live\AddOns\< AddOn B FolderName >\< files >
C:\Users\< username >\Documents\Elder Scrolls Online\live\AddOns\< AddOn C FolderName >\< files >
