essence STX and 363D
Yes, but the USB module that comes with the 363D will provide that. The Essence would be useless as the 363D is USB, unless you remove the USB part; but then you are paying £50 or so for something you wouldn't use. If you plan on getting an Essence, get either the 350SE or the 360.
Would I still be able to get virtual surround sound with the 360s?
Yes, from the Essence, which uses Dolby Headphone. Probably pretty similar to what the 363D use. I should add you don't necessarily need a Xonar Essence to get virtual surround sound. Plenty of cheaper cards have Dolby Headphone as well.
Just another question, cant find the 360s in stock anywhere, would the sennheiser game one work the same as the 360s?
