Essence STX
3 Mar 2008
Hi I have a Essence STX hooked up to a pair of Sennheiser HD515s. my question is how do i go about getting the best in terms of sound quality, or do i just install the software and be done with it :0
Thanks
Use a prog like foobar2000 to play your media, and install the WASAPI plugin to give it direct control of the SC. Don't use any DSPs (apart from the Advanced Limiter) and maybe replaygain. Done.
