Ive just done a fresh install of this, and was surprised to find that under the disk properties its created flipping loads of partitions.
Like the following:-
Primary Partitions
1. DOS 16bit <32Mb
2. DOS 16bit >32Mb
3. VMFS
4. Extended
Logical Partitions
5. DOS 16bit >32Mb
6. DOS 16bit >32Mb
7. VMWARE Diagnostic
8. DOS 16bit >32Mb
I dont ever remember ESX being that messy, and also can you get any advanced options upon install ?? With ESXi it takes the entire disk and turns it into a single datastore, whereas I want two local datastores taking half the disk each. Is there a secret hidden advanced drive options in the ESXi installation that can be enabled with a key combination.
Anyway aside from that, does everyone else get all those local partitions after a FRESH Esxi 4.1 install ?
Cheers for any help should anyone know!
Primary Partitions
1. DOS 16bit <32Mb
2. DOS 16bit >32Mb
3. VMFS
4. Extended
Logical Partitions
5. DOS 16bit >32Mb
6. DOS 16bit >32Mb
8. DOS 16bit >32Mb
