We have ESXi 4.0U2 environment over two HP BL460C blades (BL01, BL03) and a 3rd (BL09) on 4.1U1 all blades have QLogic QLE406Xc iSCSI HBA plugged into a mezzanine slot on the blade.
We had a problem with BL03 so we put it into maintenance mode, rebooted it and it came back with an error when booting of the SD card, we have had this error before basically means the SD card is corrupted.
So we power off the blade, swap out the SD cards, installed 4.1U1 via iLO as we want to be at this level, the install proceded fine, the blade rebooted, and we configured it as per our environment.
We then readded BL03 to our environment, the add went fine, however when we went to configure the storage, it was only listing the internal P410i and the iSCSI Software adapator not the QLogic cards.
To date we have tried:
Installing 4.0U2 on the SD card
Installing 4.0U2 to a SAS disk we isntalled in the blade
Installing 4.1U1 to a SAS disk we isntalled in the blade
Have flashed the BIOS and the firmware of the card, via the instructions from HP and QLogic
Currently we are using the Update Manager to patch up our 4.1 install
We are not able to power off another blade and swap the HBA cards around as we can survive on two blades just not one blade.
We can not work out where the fault lies, the hard ware has not changed, the software has not changed, used the same install media as we have alread done.
We have the blades under maintenance so we are toying with the idea of getting the blade hardware replaced but we can see the card on boot so not sure that would resolve the issue.
Can anyone suggest anything at all we could try?
Thanks
Kimbie
Thanks
Kimbie
