 - 9 Mar 2008
Hi,
Due to problems with wireless range and the price of better dedicated wireless kit, i am thinking about running a long ethernet cable from the router upstairs through the loft/celing and into a bedroom. This will probably need an ethernet cable that is 20-30m in length. This may be a stupid question, but will using a very long ethernet cable reduce its bandwidth significantly and will there be a lot of interference on a long cable from power lines in the walls/celing etc?
Thanks
Thanks
