- 8 Aug 2013
- Stoke-On-Trent
The missus has had enough of the PC been downstairs so i said ill take the spare box room and make it into my little man cave
only problem is i get rubbish signal using my TP-Link wireless card + Sky hub so i ended up grabbing a 10M OC PRO ethernet cable just set it up and had the cable running under the stairs hand rail and was planning on running it under the floorboards and into the box room but shes not happy with that. I noticed a hole around a copper pipe that goes to the rads into the box room (Bet your fed up of reading now
So do you recon it will be okay to run alongside this??
thanks (sorry about the essay just thought ide explain the situation)
) So do you recon it will be okay to run alongside this??
(it was the easiest/tidiest way to get it round part of the house).
