1 Oct 2010 at 02:45 #1 heaT heaT Associate Joined 7 May 2009 Posts 31 Is it safe to run a ethernet cable behind a radiator?
1 Oct 2010 at 08:37 #2 PhillyDee PhillyDee Soldato Joined 12 Feb 2007 Posts 14,117 Location South Shields Yup. Best off running it underneath though along the skirting board.
2 Oct 2010 at 10:26 #3 errata errata Associate Joined 15 Apr 2004 Posts 1,815 safe yes but its likely the plastics in it will age quicker ie become harder unlikley to be a problem in a dmestic setting though
3 Oct 2010 at 01:38 #4 m4rkw7 m4rkw7 Associate Joined 19 Jul 2010 Posts 679 Should be fine, just make sure it's not too close and not touching.
3 Oct 2010 at 01:45 #5 thepeganator thepeganator Associate Joined 14 Sep 2008 Posts 2,485 Location Portsmouth/Salisbury Yea as above, is fine, but best off lower along the skirting board if you can, less heat and looks tidier.
3 Oct 2010 at 03:56 #6 asim18 asim18 Soldato Joined 5 Dec 2006 Posts 15,370 As long as it isn't physically touching the hot metal/pipes you'll be perfectly fine.
