Caporegime
- 21 Jun 2006
need to buy some ethernet cables it's for someone who has no clue about computers so they need to be proper cables and not wiring needing to be crimped, etc.
thing is though they need a decent sized cat 6 cable (15-25m) and then also some fast cat 5 cables to be used with POE and roughly 15-20m in length each.
it's for a cctv setup, already have the cameras and POE router, just need the cables.
obviously the cable from the router to the PC needs to be the fastest (cat 6) and then those going to the cameras needs to be fast but doesn't need to be as fast at cat 6 just to help stop any bottlenecks, etc.
does any cat 5 or cat 6 cable work with POE or do you need special POE cables?
also wheres the best place you buy cables from (not cabling) a lot of fake stuff on ebay/amazon, so wondering what legit sources there are out there that are cheap.
