Ethernet extending
9 Feb 2007
Hey guys just wondering, if i take a normal ethernet cable cut it, and connext by colour to another longer cable.
Do you guys think, that there will be any problem?
just get an inline coupler, far easier and when you just splice the cable together you run the risk of adding a lot of signal degrigation to the line.
Also remember that ethernet cable is limited to 100m maximum. So if you join 2 cables together, make sure the total lengeth is not 100m
