For what it's worth
Standard Ethernet Connection: Draytek 2600G Router
2 Devices connected using Cat 5e Ethernet cable to a switch
Size of file
4,571,424 KB
Time For Wired
7 miniutes 12 seconds
average network utilisation 92-94% of LAN adapter
Ping results
Reply from 192.168.1.11: bytes=32 time<1ms TTL=128
Ethernet Over Power using Netgear HDX101 adapters
1 Device connected using Cat 5e Ethernet cable to a switch, the other device connected downstairs using 2 Powerline adapters into a switch
Size of file
4,571,424 KB
13 Minutes 20 seconds
Network utilisation at most 53%, at worst 30%, varying over time, less stable than wired.
Ping results
Reply from 192.168.1.11: bytes=32 time=4ms TTL=128
Reply from 192.168.1.11: bytes=32 time=1ms TTL=128
Reply from 192.168.1.11: bytes=32 time=3ms TTL=128
Reply from 192.168.1.11: bytes=32 time=2ms TTL=128
Reply from 192.168.1.11: bytes=32 time=5ms TTL=128
Reply from 192.168.1.11: bytes=32 time=6ms TTL=128
Reply from 192.168.1.11: bytes=32 time=9ms TTL=128
Reply from 192.168.1.11: bytes=32 time=18ms TTL=128
Reply from 192.168.1.11: bytes=32 time=20ms TTL=128
Reply from 192.168.1.11: bytes=32 time=13ms TTL=128
Reply from 192.168.1.11: bytes=32 time=10ms TTL=128
