Built a new pc over the weekend and having problems with the ethernet port.
The motherboard is a Gigabyte x58a-ud3r rev2. All the motherboard drivers are up todate and im running Windows 7.
The cable is connected to a D-link router(provided by Virgin Media). The cable worked fine on my old pc and works fine on my laptop also.
When you plug the cable in the network sharing on windows 7 says its Enabled, identifying, Network cable is unplugged.
At the moment its working now but the download speed is only at 9MB(should be 20mb). The laptop is running at 20mb on wireless and 20mb when you plug the same cable in.
Any ideas to what is the problem?
