ethernet to wifi adapter
16 Mar 2007
hi,
i need a device that will change an ethernet wire plugged into a router into a wireless signal.
any sugegstion?
thanks
You need a Wireless Access Point or Wireless Bridge depending on what you are trying to do.
well i have a ethernet wire coming from the router into my room and i want my room to have wireless capability so i connect my laptop and pc and ps3 simultaneously...
Well....you could just use a network hub, to make that 1 cable in to...quite a few (5-8 port hubs are very cheap).
Or as said above, by using a wireless AP (I use mine for 2 laptops and one PC).
I have the Belkin N1 and i run my pc (wired) through and my wifes laptop,my sons pc upstairs,My xbox 360,And my bro in law lives next door and i let him connect with his laptop too :)
