ETS2 - Triple monitor setup
12 Dec 2005
I have 3 monitors, 24 inch but all different models
I have the triple setup working fine apart from the monitors being unlevel ingame, for example when I'm driving, the image on the monitors appears to be higher or lower than the other which makes things uneven
Is their any way to fix this
Not that I'm aware of. Can you not do it via a graphics card utility? Eyefinity does bezel and height correction...
Are the monitors the same resolution?
This any help:
https://support.amd.com/en-us/kb-articles/Pages/DH-014.aspx
Could you take a photo so we can see what is going on.
