I need to change the lock cylinder on my front door. Can anyone recommend one please? Is the 3 star versions the best that you can currently get? I appreciate the lock is only as good as the weakest point and it wont prevent a brick through the window but might as well fit a decent one.
Can anyone recommend a supplier too? Ideally, I need 8 keys with it rather than get extras cut after.
Thanks
Thanks
