Before I start I just want to say that I've had a triple monitor setup working before in ETS2 with the exact same monitors and same graphics card. The only thing that has changed is I went from 8GB RAM to 4GB RAM and I did a fresh OS install
I've set the monitors up in Nvidia surround, I've edited the ini file in ETS2 to enable multi monitor. When I open up ETS2, it loads until I try and load into the game, then I will just get a black screen and it will crash to the desktop. If I disable nvidia surround and use just the one monitor it will work fine
Could it be something to do with going from 8GB ram to 4GB ram, maybe it's not enough for triple monitors and ets2? But if that was the case wouldn't it crash differently
