- 19 Oct 2002
- Shakespeare’s County
Oh sporry read as Octopus. I assume OVO anytime will always be the cheaper for the car aslong as they can see the data from the Ohme then take it off the bill.Thanks for confirming.I don't mind this time but going forwards I'd like to understand the correct procedure. I've reached out via email to Ovo Charge Anytime to tell me what exactly I need to do.
EDIT : T&C here i assume the you need to have OVO access to your Ohme account to validate the EV use.
2. What is Charge Anytime?
2.1 Charge Anytime is an add-on for OVO Energy Customers with a compatible EV or charger. With Charge Anytime you pay a lower rate when Smart Charging your EV whilst the rest of the energy you use is charged at your tariff’s usual rate.
2.2 Our partner Kaluza provides the Kaluza Flex Platform, the intelligent software platform that powers the Charge Anytime add-on that you access by downloading the Charge Anytime App (the “App”) or your charger manufacturer’s smart charging app. Kaluza will gather data from your EV or charger via the Kaluza Flex Platform, and report your EV charging consumption data to OVO Energy so that we can credit your account correctly. Kaluza will also use the Kaluza Flex Platform to smart charge your EV so that it can be charged at times when the grid is likely to be greenest. The App is provided by Kaluza, so you will need to agree to Kaluza’s End User Licence Agreement (“EULA”) when you download the App.
2.3 Provided you meet (and continue to meet) the Eligibility Criteria (see section 5), you can sign up to Charge Anytime as follows:
- If you have a compatible EV, you can sign up to Charge Anytime for free by downloading the App (available from Google and Apple stores), registering your details and creating an App Account and completing the sign up journey;
- If you have a compatible charger, you can sign up for Charge Anytime via your My OVO account by completing the sign-up journey. You will also need to download the manufacturer’s smart charging app in order to connect to the Kaluza Flex Platform.
3. How it works
3.1 Charge Anytime works as follows:
- Your home energy rate will stay the same, but the energy consumed by your home EV charger will be charged at an effective rate of 7p a kWh when Smart Charging. Rather than being charged at a lower rate for your Smart Charging, you will receive a credit to your bill (Charge Anytime Credit) – see section 4.
- You will be charged at your standard plan rate for energy used to charge your EV while in Boost Charging mode.
- You will also be able to see insights about your EV charging and the savings you are making with the Charge Anytime add-on in the “Your EV” section of your OVO Energy account (either via a web browser or the My OVO App).
3.2 Charging insights are only currently available if you connect to Charge Anytime via a smart charger, and will be available for EVs in due course. We will let you know when this happens.4. Charge Anytime Credit
4.1 All electricity you use will initially be charged at the normal unit rate you pay for your OVO energy plan – and these rates will be reflected in your live balance and on your bill, along with your normal standing charges.
4.2 In the first working week of each month, you’ll receive a credit based on how much of your total electricity usage in the previous month went into charging your EV (as calculated by the Kaluza Flex Platform). This will be your Charge Anytime Credit.
4.3 The Charge Anytime Credit provided will effectively mean that each month your total balance will be equal to what you would have owed if your EV Smart Charging consumption had been charged at the Charge Anytime Rate (currently 7p a kWh, inclusive of VAT).
4.4 All other energy use will be as per the rates on your standard OVO Energy plan, namely:
- All home energy use will be charged at your standard OVO Energy plan rates for electricity and gas;
- Standing charges (or "fixed charges") associated with your plan will remain the same; and
- Boost Charging will be charged at your standard OVO Energy plan electricity rate.
4.5 The amount of credit you will receive each month will vary depending on how much you charge your EV that month, how much you Smart Charge, and how much you Boost Charge. For an example of how your Charge Anytime Credit will be calculated, please see our FAQs.
4.6 Only electricity that has been used from the grid for Smart Charging will be considered in the Charge Anytime Credit calculation. For customers who have solar PV installed in their home, OVO can only currently offer Charge Anytime Credits, where the charger is an Indra Smart Pro Charger (and installed with a house current clamp). All other local solar energy that goes into EV charging will be excluded from the Charge Anytime Credit calculation.
4.7 If you are a Direct Debit customer, your Direct Debit will not be affected by the Charge Anytime Credits applied to your account with the Charge Anytime add-on. If you have any Charge Anytime Credits left when you leave OVO Energy, they will be offset against your final bill.
car twins
"Oh look, there's an us" or if it's exactly the same colour and model, it's an "Us Us!"
