There's an AWD LR model Y for 23k with 26k miles, from Mar 2022. Anything I need to look out for when viewing? Should it have had its brake service done?
It’s just out of warranty so you need to do all the same checks you would do for any out of warranty car.
On a 3/Y, squeaks/play on the suspension is the main thing on these. Check the inside edges of all the tyres, if the are worn it’s a tell tail sign of worn suspension components.
As for brakes, Tesla recommends they are periodically stripped and lubed in countries which salt the roads heavily but I doubt you’ll see an invoice for that and hardly anyone does it. Brake fluid is change as needed so may not have been required (or checked frankly). Check the brakes work and check the disks for any corrosion/scoring, if it’s present, they may be an issue. If they are clean, they are fine.
The other main service item is the cabin filters (regular and HEPA), both should have been replaced, the regular filter twice at 4 years old.
Other than that, cosmetic condition mainly. Make sure there are no chips or cracks on the touch screen (expensive). For thy model year, it should have a Tesla granny charger and a 5m or 7m 3-phase 32A type 2 cable included. There should also be a Tesla branded fist aid kit and warning triangle also. If it doesn’t, knock them down, the granny charger is £200 to buy again.
The early cars didn’t come with a parcel shelf so it may not have one. Check all the mud flaps and the PPF on the bottom of the back doors is present. If not, your body work will get trashed quickly from road rash.
