If it’s a standard range model y? If so 180 miles range isn’t that’s far out of expectation if it’s not being driven particularly economically. If your not used to driving a BEV then your probably not getting the most out of it.
If it’s the long range dual motor, you’d have to be driving it pretty hard to only get 180 miles out of it.
I have a standard range model 3 and I did around 220 miles today with 3 stops and got back with 14%. Driven to the speed limit the whole way. Yeh, I’ll get more out of it than a model Y, but it’s not that much more.
The tesla nav only sends you to their own chargers, great if they are en-route, not so much if not. There are plenty of other decent sites out there once you get to know where they are.
It says Dual Motor on the back and it wasn't being driven hard.
Without meaning to repeat myself but yes. Scan my Tesla gives you the current state of heath for the battery (E.g. current max capacity vs. design capacity) and a cumulative AC and DC charge amounts for the battery pack.you actually have that data, or you are speculating ... I've just seen bjorn with an obd reader that shows current/dynamic battery & motor characteristics,
but, even, applications like teslafi, apparently won't give historic data, say, from a previous owner.
Noobies will never get decent range on a first drive out... well unless you are my wife and consistantly gets more![]()
This could be it.By driven hard, I don’t mean ploughing down the motorway 90mph but more like using most/all of the acceleration available when you get the opportunity and using the brakes over regen.
for example on the journey I mentioned yesterday, I used the brake pedal once when someone pulled out in front of me. Everything else was all regen.
after ninety miles we stopped for breakfast and it had dropped to 51% charge.
The services had no Tesla superchargers and the "fast" chargers they had were all in use so he plugged it in to a non fast charger.
Cambridge on the A14, there are some fast chargers that were all in use on the way up so we had to go to the other bank, that only gave 25kw. On the way home, we got one of the faster ones and it was reasonably quick.What was a non-fast charger? Which services was this?
A14 and the southern section of the M11/A11 is pretty poor for chargers, they are there but just not in the volumes needed.Cambridge on the A14, there are some fast chargers that were all in use on the way up so we had to go to the other bank, that only gave 25kw. On the way home, we got one of the faster ones and it was reasonably quick.
You drive a lot...? lolA14 and the southern section of the M11/A11 is pretty poor for chargers, they are there but just not in the volumes needed.
Cambridge services is very under served. Ionity is fast but every time I have stopped there they have been full and the slower gridserve units are normally in use as they have historically been cheaper. That said you should be getting more than 25kw from them, more like 45kw.
There are only 4 old style super chargers at Birchanger services on the M11 and a couple slow gridserve units. Also naff.
There is a large Tesla site just off the M11 on the south side of Cambridge but there are few facilities.
If you head up the A14 to the midlands, the next decent rapid chargers are not until Rugby assuming they are now fixed… apparently only 4 of 12 were working last week, one was destroyed by someone reversing into it(again…!).
Going north on the A11 by contrast is charger heaven. From Mildenhall you have MFG, then Tesla, then Ionity and the big the Gridserve on the outskirts of Norwich.
would miss the instant power though
It'll be a year before we do the journey again, going by this trip, I expect we'll be doing it in a car with a real engine.A14 and the southern section of the M11/A11 is pretty poor for chargers, they are there but just not in the volumes needed.
Not really, I just live in East Anglia so I need to travel on those roads often to get anywhere worth going.You drive a lot...? lol
I am impressed by your knowledgeNot really, I just live in East Anglia so I need to travel on those roads often to get anywhere worth going.
That said I know roughly where all the fast rapids are in the areas I frequent should I need one. Just like anyone else would know roughy where all the fuel filling stations are.![]()
those figures there are what you'd see on a fat E-tron or an iPace, being driven at the speed limit.
No. Straight 6 and it’s good.That is a slight concern. I thought it was a BMW engine though.
