EV tariffs I need POWER!!!!!
233
233
21 Nov 2004
Wishaw
Having started down the slippery slope of electricly propelled vehicles with a Volvo phev and a zappi 7kw charger things have progressed somewhat
The Volvo I couldn’t care less just plugged it in any old time and topped it up hey it’s a 18kw battery it’s not too bad……
Then i was fortunate enough to be handed a Tesla through work. And I now have no diesel and a hefty 100kw battery to fill ideally every night.
Now most tariffs I see only offer a max of 5 hours at cheap rate before going back to normal pricing this is gonna get real pricy real fast and I can’t get a 3 phase supply in
Can anyone suggest a decent scheme/tariff that will give me a solid 8 hours a night of charging ?
Pretty sure Octopus do a £30 a month EV tariff which means you can fill as much as you want, or they did do.
Bugger, it's over subscribed - https://octopus.energy/smart/intelligent-drive-pack/
IOG sounds like your best bet, currently you get all the cheap charging you need to reach your set limit.
Soon (they're still umming and arring on exactly when) this will get limited to only 6 hours of cheap smart charging a day and anything over charged at normal rate.
The drive pack I can't see ever coming back in anything like it's current guise.
Most likely a few days a week at least I’ll be doing 150 miles thinking of i spread those days amongst the others I’m only doing 60-70 miles I could just charge 5 hours every night ….. and top up at a supercharger if I’m stuck
If we work on an efficiency of around 3mi/KW then you'd need approx. 7 hours to recover all the charge used for that day.
So I'd say if you go for octopus and use the full 6 hours every day even on your lower usage days you should be able to keep topped up without any real issues. Even easier in the summer when I'd guess you'll be getting 4+mi/kw
150 miles at 4miles/kwh = 37.5kwh
say 40kwh, which should be doable in a night's charge
edit: beaten :cry:
A Tesla with a 100kWh battery (typically found in Long Range Model S and Model X vehicles) will generally deliver between 200 and 300 miles of range in winter conditions.
Easy peasy.
Before you go making any drastic changes or sinking thousands into a new electricity supply, just try a real EV tarrif and see how you get on. From the sounds of it, you’d never NEED to have a full charge although I understand the mental aspect of preferring to start a long journey on 100% battery.
It’s a huge battery, a car with a reputation for efficiency and you have home charging so I think you’ll be alright.
Also, even peak charging costs will be less than using a supercharger if you find you need a bit extra or really want to have 100% on a regular basis.
Are you actually going to be emptying it every day? Also why did they give you a Model S/X? Assume you also mean 100kWh pack.
6 hours x 7kWh = 42kWh take away losses, so ~40kWh. without going outside of IOG 7.5ppkWh
40kWh = 80 miles at 2mpkWh, 120 miles at 3mpkWh, 140miles at 3.5mpkWh, and 160 miles at 4mpkWh.
Over the year a Model S/X should achieve between 3.0-4.0mpkWh. So in the winter you might end up paying a few quid extra per week if you don't get any intelligent slots.
If you find out you've actually been given Model 3 or Y then you'll get way more mpkWh.
maths aside, per diddum's comment
Partnership offers UK taxi drivers savings of more than 40% on public charging as EV adoption accelerates
Electroverse said its platform already provides more than one million drivers with single-tap access to around 80% of public chargers across Europe. The service aggregates multiple charge-point operators into a single app, reducing the need for drivers to manage multiple accounts or payment methods.
serendipity
Nope definitely an X P100. Currently parked on my driveway. Worst comes to worse I’ve got 3 supercharger sites on the commute along the M8 be interesting to keep tabs on the actual performance changes over the year
Superchargers in daytime are still more than a home tarriff once you have run out of hours on the special rate. Not sure what the issue is other than what you have described already.
Intelligent will give you 6 hours
The IOG tariff will start only allowing 6 hours soon.
So I've opted to get 6 * 440W solar panels.
and a 20kWh Rayleigh Battery with a 5kW Inverter.
I'll be installing it all myself so total cost will be around £4000.
This way, On days where I don't need more than 44kWh over night into my Tesla, The battery can also charge at 7p kWh, then discharge throughout the day.
My house seems to use 10-15kWh during the day.
So I'll be running the house on 7p kWh 95% of the time and also have some cheap power for my car to suck in when needed.
Pay back is 2Years based on my calculations.
I'm going for ZERO export to the grid too.
