Event Viewer Errors :(
Can't type for toffee
Don
14 Jun 2004
Newcastle U/T
Anyone got any Idea as to how I can remedy these ?
Its startin to really annoy me :(
It seems each one is when BF2 drops to Desktop, it just dissappears, no error popups or anything.
Which error do you want fixing? If there's a certain one, open up the error and take a screen shot.
NFS:MW used to crash to desktop when my computer was hot and when there was not enough volts going to it...
Windows saved user pcname\user registry while an application or service was still using the registry during log off. The memory used by the user's registry has not been freed. The registry will be unloaded when it is no longer in use.
This is often caused by services running as a user account, try configuring the services to run in either the LocalService or NetworkService account.
Thats the 1517 error
other seems to be diff errors each time, fear and cs
just checking and the last one on there was a few hours back so BF2 doesnt seem to be making an error code on there
I believe you dont need to worry about this one, every XP machine i have seen gets this, a program like windows defender/avg/adaware normally is using the registry when you turn off.
