Event viewer help???
28 Jul 2004
Hi,
From looking through my event viewer at the Application tab I can see that every time I reboot the machine I get a warning (as pasted below).
Is there a way to find some more information about which 'service' is causing this???
I am running Windows MCE 2005 with all the latest service packs etc. I only built this box at the weekend (fresh format and install), and have gone through the performance guide in this forum to speed it up (disabling a few services of the services). I barely have any additional software on it yet, as I was/am trying to get a good base build first.
Cheers.
:confused:
Event Type: Warning
Event Source: Userenv
Event Category: None
Event ID: 1517
Date: 11/09/2007
Time: 11:12:42
User: NT AUTHORITY\SYSTEM
Computer: MEDIAPC
Description:
Windows saved user MEDIAPC\Stu registry while an application or service was still using the registry during log off. The memory used by the user's registry has not been freed. The registry will be unloaded when it is no longer in use.
This is often caused by services running as a user account, try configuring the services to run in either the LocalService or NetworkService account.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Can you turn off the auto restart in that OS? I'm not sure but check it out.
Also if you have new drivers on it, roll each one of them back a set or two, start with video. I've never had Event Viewer help me fix a problem yet.
