Ever felt a lot better about your rig after you've solved a software issue?
25 Jul 2006
Taunton
for example, i've got a fairly good laptop that cost a fair amount, but due to graphics drivers not being very good it would take a while to start up as i would have to wait for the screen to flash and then it would load my wireless and bluetooth so i could actually use it. now due to some new drivers it flashes straight after logging on so it is ready to use straight away, no waiting around :eek::D
also had a common annoying problem to do with audio drivers. got them updated and there is no more stuttering, currently loving my laptop 110% :D
your feelings? :)
Yes I know the feeling, it wears off eventually, I generally find at least something new every day, I create problems just so I can fix them, seriously.
Yep definitely, i keep my computer in tip top condition.
Not because I'm worried about performance, (well to a degree). But just because I could not like with a computer that errored or had problems when i come to do stuff. I also have a lot of applications installed that i barley use. But i can just press the windows key and type in <application name> and it just WORKS. :)
I figure i paid for the computer it should do exactly what i want. :)
(although that's slightly hippocrytical as i cba to RMA my motherboard. But it doesn't effect day to day operation)
Also I'm very VERY anal with my computer. Everything has to be arranged perfectly :) aha
