The Everest 'reading' 3613 is I believe 425x8.5 i.e. max speed rather than running speed.
Am not an expert though!!
Are you running Auto voltage to cpu for your overclock ? If not what did you set in bios?
i manually set it to about 1.9V round about. why?
So just wondered if it was on auto volts or not. (Will be giving my 9550 Cpu a bit of a boost over the next few days - so all info helps)
Do not think you have an Everest 'problem' - it's just telling you that at standard setting of 333fsbx8.5=2.83 whereas at your setting of 425fsb x 8.5 the max speed is 3.6 .
No need to lose any sleep imho![]()
Temps ?
