You can adjust the Tjmax in Everest for the CPU but not the GFX Card. You're GFX Card temps should match. In Everest, the one you need is GPU Diode (DispIO).
To change the Tjmax, go to File -> preferences -> hardware monitoring and select 100c as thats what I assume it is for the Q6600.
