Everest wonky readings?
27 Jun 2007
England
Has anyone else had odd readings off everest?
I upgraded to a p5q and quad and since then its been playing up, gives me random readings of 123C on either the GPU or CPU, then goes back to normal, also says unknown for motherboard name and has no readouts for the memory info's, tried re-installing but is just the same :confused:
Thanks in advance
submit a report with everest and it will send all details to support and they will send a beta i had to do the same with a skulltrail and blackops and the beta works fine but dont believe the core temps
Yeah I've had weird readings as well. AT one point my cpu temp was above shut down temp according to everest.
