everRun software for replication
30 May 2004
Uk
Has anyone ever tried this or use it permanently? We are looking to evaluate it shortly for server replication. Is it any good? Pros/Cons etc.
Cheers
We are running Marathon EverRun FT for our Exchange server.
We have 2 identical servers whcih replicate each other, they both host a virtual server (it is the same instance of the server so when you move the mouse on one it moves on both etc.) which has Exchange installed, fault tolerance wise it is superb, can handle anything for a NIC, CPU, Disk to entire server failure without users even knowing. Before I go off on pros/cons, which version are you looking at as we are running EverRun FT 7.1.1 which is completely different to the VM version which is Citrix XenServer based I believe.
Cheers for reply.
We are looking at EverRun 2G. I believe it is version 5.1.1. It will be used on 3 servers (DC, Terminal Server & Database Server). These will all replicate to 3 backup servers for complete fault tolerance as the customer could lose millions pounds if they were to experience any downtime.
Any help regarding experiences of the software would be helpful.
Cheers.
