Greetings All,
I have a network comprosing a 16port managed switch, an 8 port POE switch for cameras connected to the 16port. All used to fed by a Draytek 2820n on ADSL. Worked perfectly. No however I have FTTC and using the supplied Hub 6 am sync'd at 54 down and 9 Up. Issues with the closed nature of the Hub 6 meant I started down a path of upgrade testing. I told BT I was testing and asked my line not be throttled (error checking from constant disconnects) So assuming this went to plan can anyone shed any light on the following results please.
Hub 6 54/9
Hub 5 52/8
Echolife 612 43/6
Echolife 512 43/6
ECI CPE Type 1B 44/6
Billion 8800NL R2 45/6
Asus RT-AC88U 47/7
Draytek 2860n 44/6
Crap results compared to the Hub 6. I would rather not use the Hub 6 as it is a "barn door" when it comes to RFi and needs to go. Anyone got any thoughts.
Cheers
Hub 6 54/9
Hub 5 52/8
Echolife 612 43/6
Echolife 512 43/6
Asus RT-AC88U 47/7
Draytek 2860n 44/6
Cheers
